Is there a way to change the time length Atomix uses to go from one Turntable to the other. In most cases it cuts off one song way to early.
geposted Wed 14 Mar 01 @ 12:05 am
No there is no way for the moment. The only thing you can do is to know when the mix will begin : the time is behind TO END. So, if you think the mix begin to early, you have to put the automix off. I agree with you, it is one of the few bad point of the soft.
geposted Wed 14 Mar 01 @ 5:12 pm
promise we will working on the automix for next versions but not 1.2, or you will wait again some months!
geposted Wed 14 Mar 01 @ 7:21 pm
Thanx to both of you for your info. Other then that the software is great.
Thanx again
MedMan
Thanx again
MedMan
geposted Sat 24 Mar 01 @ 5:14 pm
