Forum: Old versions
Topic: How te resume recording
Hi,
When recording a mix to burn on cd I sometimes (usually somewhere at the end of a song :) make a fault and so I have to start all over again... isn't there a way to start again from some point...?
geposted Mon 19 Mar 01 @ 6:10 pm
mamaPRO InfinityMember since 2003
Sir,
unfortunately there is no way to start again from a point inside AtomixMP3 when recording.
But you can stop recording, edit the wave (i.e. cutting it at this point or fade out), encode the record to MP3 and use it like a song to mix the next song in.
Regards
mama
geposted Mon 19 Mar 01 @ 6:39 pm
