Hello,
So far I am very pleased with your software. Please continue to "aw" us with your updates. I would like to know if it is possible to play/mix several songs at the same time. If so how?
Thanks
Thanks
geposted Tue 10 Apr 01 @ 4:46 pm
2 possibilities:
U got 2 sound cards and a mixer:
u launch both songs on the player and use ther mixer to set the volume
U got 1 sound card (should be your case):
u launch 1 song on each player and Then use the crossfader.
It's the the horizontal bar between both player. When it is pushed to the right u ear th eright player, and when pushed to the left the left player, and in the middle both player
If u want to ear more than 2 songs, u can activate the multi-instance in the option pannel. And launch a few atomix but quite hard to manage properly!
cTiger
cTiger
geposted Tue 10 Apr 01 @ 6:30 pm
No, it´s not hard if you use a second graphics card and a second monitor. Then you can handle 4 songs without any problems!
mama
mama
geposted Tue 10 Apr 01 @ 7:37 pm
I see. I have tried other demo versions and I am able to play at least 4 tracks at the same time, without adding any hardware. Maybe I should post something like that to the wish list. I think just adding 1 more turntable would be ideal. Thanks for your help
Tyrone
Tyrone
geposted Tue 10 Apr 01 @ 10:13 pm
