Forum: Old versions
Topic: Buying Equipment
Ok That's it!!! I want to invest my loot into a second sound card. I need an external soundcard with a USB port (for my laptop). I just moved to China so I have NO IDEA where to get this. So my question is: Where the HELL can I buy this ONLINE!!
And more importantly: WHICH darn soundcard should I buy?
ALSO!!! i have read in past postings that it is possible to get one of those audio in/out Y cables with 4 male ends. I currently have the Y cable with 2 male ends. where the HELL do i find one with 4 male ends????? I've looked all over stores here in China and HAVE NOT FOUND em. WHERE can i get one online? (if it exists!!)
Thanks in advance,
DJ 56K
geposted Mon 24 Sep 01 @ 10:42 am
a PCMCIA soundcard is better than USB device.
try to www.digigram.com
geposted Thu 27 Sep 01 @ 12:32 pm
a pcmcia soundcard is better than usb
www.logicaltools.com
Interesting, could you elaborate on usb and pcmcia?
I am intending to buy a laptop and use atomix with 2 outputs: onboard sound and pcmcia or usb. Or can I use 2 outputs from a single usb or pcmcia solution?
Who has experience with running atomix from a laptop? Will it work?
Who has recoomendations about which brand of laptop, onboard sound chip, usb sound card, and pcmcia sound card to buy?
Any suggestions are greatly appreciated!
Best regards,
Arie in 't Veld
geposted Thu 18 Oct 01 @ 10:13 am
