Forum: Old versions
Topic: shoutcast + automixmp3
hi
are there any plugin that i could use to stream my mixes live to a shoutcast ? if there isnt, how would i go about doing such a thing
could you email me the answers to davidr@skyforge.net
i will try and check back here as much as i can
david
geposted Wed 28 Nov 01 @ 5:32 pm
try the shoutcast plugin u can download at www.shoutcast.com
if the plugin gives u errors use it on winamp and choose to use the input from your soundcard instead of what winamp is playing..
geposted Thu 29 Nov 01 @ 12:22 am
nateHome userMember since 2001
Definitly use it inside winamp itself, it prevents latency problems... it also allows you to use Line-in input, where you can route the record output of your mixer or amp to the Line-in of the soundcard.. allowing you to stream the post-output mix.. handy if you use a post-mix EQ or effects... or external mixer..
-Nate
geposted Mon 03 Dec 01 @ 10:32 pm
