i download the effects into the atomix effects folder and when i try to unzip them nothing happens. what should i do in order for the effects to work properly.
Greatly appreciate your help,
Omar
Omar
geposted Thu 06 Dec 01 @ 9:37 pm
You must load them! In the effects panel of AtomixMP3 you find an "eject" button at each effect. If you click on it, you can load the effect you want.
geposted Thu 06 Dec 01 @ 10:11 pm
That is what i do but the thing is that when i press the eject button, nothing appears in that folder. the problem i'm having is that i can't unzip the downloaded file. When i try to unzip it, nothing comes up in the new unzipped folder. I don't know why though.
geposted Fri 07 Dec 01 @ 1:58 pm
DLL files are hiden by default in Windows. You must go to the folder options to display them !
geposted Fri 07 Dec 01 @ 4:46 pm
Thank you, got it now
geposted Fri 07 Dec 01 @ 8:48 pm
