Forum: Old versions
Topic: how are the system requirements???
Hi everybody, I'd like to ask a question:in the version 2.0 how are the system requirements???I have a k6-2 373 with 128 mb sdram and a sb live, and the 1.12 version(demo) works perfectly,but the 2.0 version, the beats visualization works VERY slowly, when I playing 2 tracks...why???My computer is too slow?Pleeze, help me!
Thanx,
Dj P@lox
geposted Mon 10 Dec 01 @ 10:39 pm
If you want to have all graphics on, your cpu i think i slow.
But even with this cpu you can run without problem atomixmp3 but use the classic skin. Another way is to modify the skin.xml file and take out the beat graphics , on the top of the screen. The skin.xml file can be like this.
I'm sure you could picl up a K6-3 500 mhz chip that would work in your board for around $30-$50 on Ebay....
how do i edit the .xml file?
i can't figure out which part is the visualization
to edit the file
first make a backup of the file
then delete everything from to
including the tags
then save it and your done
open with notepad the xml file ( classic.xml, void.xml ...) and in second paragraph you will see this
in usual the numbers are "740" , "65" change this to "0" like this
I hope i help
