I've seen around the forum that that you do not need to use a second soundcard to mix through a headphone..
I've heard about USB devices (Telex) that provide basically the same function. If i were to use on of these would i need an external mixeras well.
What are my options other than buying another soundcard to perform some professional mixing thru headphones on my own.
geposted Wed 26 Dec 01 @ 4:40 am
          You need either a 3D soundcard (USB only for laptops) or a second card. And, very important, the full version. Then you can monitor with your headphones on one channel and listen to your mix on the other.
    geposted Wed 26 Dec 01 @ 10:38 am
          Or you use a Y-splitter on your soundcard, if you own the full version.
Greetz, ikke
(Doesn't an USB soundcard works on a desktop, Yan-X?)
    Greetz, ikke
geposted Wed 26 Dec 01 @ 12:52 pm
          Sorry, it's mama, not Yan-X
