I record to my hard drive , all fine and dandy, but as I am mixing songs, right at the end of the transition period between the two songs ( the slider is about 90% to one side ) just as i move it that final mm so its totally at one side atomix misses a second in the recording and it sounds crap!
You don't hear it when its playing just on the recording.
Any Ideas??
Any Ideas??
geposted Mon 14 Jan 02 @ 4:26 pm
are you recording to Sound Forge? if you are, go to options, preferences, then the "Perform" tab, uncheck both checkboxes, it worked for me! :)
geposted Thu 24 Jan 02 @ 3:11 am
