Ok, i searched back into the forums, and found out that Atomix Version 2 has problems with skipping while recording.
Here is my system specs....
AMD 850 MHZ Tbird Processor.
MSI KT266 Pro 2 RU
256MB Crucial DDR Ram
Windows 2000 W/ Service Pack 2
Via 4 N 1's. (Most Current Version)
SB Live X-Gamer (Original SB Live, NOT 5.1)
Onboard AC97 Sound Card.
Upgraded to DX 8.1
And at the end, i still get skips no matter what i do. I tried to use that external program like Wav REc, but it records everything that i do. For example, when i try to move the beat on the other mp3 that i am trying to blend in to, it records that.
Any help is greatly appricited.
I really want to make my mix, but the skipping is horrible, and ruins my set.
thanks in advance.
MSI KT266 Pro 2 RU
Upgraded to DX 8.1
thanks in advance.
geposted Mon 21 Jan 02 @ 5:44 am
Tried a different sound card? AC97 Onboard sound is absolutely horrid, I'm forced to use it for my second channel for the time being and I hate it.
geposted Tue 22 Jan 02 @ 2:15 am
I should have actually read your specs better, you do have an SB Live in there, LOL :D
I don't know then... what mode are you mixing in? External mixer, software mode, hardware mode, monitoring with headphones?
geposted Tue 22 Jan 02 @ 2:16 am
I am in software mode because thats the only mode i can record in, and thats the only mode i can use the treble, bass and mid knobs.
Also, i use the AC97 sound card as my monitor. I monitor with headphones on that soundcard, and then use my regular speakers to output sound.
geposted Tue 22 Jan 02 @ 10:01 am
change the colour settings to 16 maybe will help
geposted Mon 28 Jan 02 @ 4:16 am
I have the same problem while mixing drum and bass - you can actually see the beat graphic skip over in the beatmatch window - drives me crazy when you mix 2 songs perfectly and upon test listening the mix you hear a skip! my specs are right up there and I still get it ALL the time...
P2 933 mhz
1 GB SDRAM
60GB drive
SB 5.1
Win98
HELP!
P2 933 mhz
1 GB SDRAM
60GB drive
SB 5.1
Win98
HELP!
geposted Wed 13 Feb 02 @ 10:10 pm
