Forum: VirtualDJ Plugins
Topic: How do I use 2 Plugins or Effects at once w/o MuchFX2
b/c I cant seem to get it to work properly. The plugins wont load up and wont add so i dont really like it. Im sure im doing something wrong but is there any other way?
geposted Tue 11 Dec 01 @ 7:42 pm
I dont know about demo version but in full version you just load the effects from the effects folder, you clik on it and you can have 3 effects at the same time in the player.
Agreed, I can run three F/X at the same time. SOmetimes you can get a really cool effect by having different effects set to each deck as you crossfade!
Be sure to put them in the effects folder.
And you´ll need the full version. In the demo, this feature isn´t available!
