Forum: Old versions
Topic: If VDJ wont start up with DJ-Console
Do you have a problem starting VDJ using Windows2000?
If you get a Error Message after starting VDJ with a left-klick on the Icon( right after the splash screen is coming up, and a box saying that the console could not be found, reconnect, restart and so on....) easily remove all USB drivers ("root hub") from within the Device-Manager and reboot!After rebooting, the OS will find and reinstall all the necessary drivers, so dont hurry and be paitient till a popup window says that the drivers are installed again!
I´ve tried this out on a Elitegroup ECS and an ABIT KT7 Board. In both situations this helps starting VDJ as it should do without a error-message.
Dont ask me if this belongs also to WIn98/XP, im also wondering because this issue is not listed in the faq.
hope that will help some of you!
Greetings from Austria
DJ-Reedbeat
geposted Sat 10 Jan 04 @ 8:29 pm
