| Autor | - Topic: Rate it! - |
Hiya guys,
Download this... http://syfoon.gotmaryjane.com/music/Syfoon_-_Bacon_n'_Eggs.mp3 Mirrored at; http://www.noiseport.org/Syfoon_-_Bacon_n-_Eggs.mp3 (Be warned, its 50.2MB, and, for the lil wimps out who might get scared unless I warn you, it contains some swearing *gasp* :P) Tell me whatcha think of it? (Good DJ's - Reckon the mixes are any good?) Cheers, - Bren (Syfoon) |
Did you do this mix? It's awesome!!!!!!!!! Can I play it at an upcoming gig? |
Very Good. Any chance of a track listing? Was this done on Atomix? If so, what version? |
Yep, I did mix it :)
It would be a lot easier for me if you just contacted me via AIM or e-mail... http://www.syfoon.com/contact/ - Bren (Syfoon) |
Dude you never fail to impress me! Don't stop rockin! :) |
What's going on when I input either of the two addresses you gave me for the mix? When I type it in IE, it does the 'page loading' thing with cursor turned to egg-timer. In the bottom left-hand corner of the IE wndow there is a hard drive icon with a small red arrow pointed into it. Does this mean it is downloading? and if so, where to?
I left it for ages and when I came back the page had stopped 'loading' and was blank. I did a search for the mix but found nothing. I then clicked on 'refresh' which brought up a player on the webpage which then proceeded to start playing the mix. Didn't it even download the mix to a TEMP folder? I cannot find the mix on the hard drive anywhere at all. I just want to download it and be able to play it in WinAmp or something. What do I do???? Thanks |
To download the mp3 enter this in your browser address bar,
http://syfoon.gotmaryjane.com/music/ Then right click on 'Syfoon_-_Bacon_n'_Eggs.mp3' and select 'save target as' Hope this works for you. |
Thanks, that worked perfectly. It was an obvious answer, I can't believe I didn't think to do it. Doh! |
Just started listening to the mix, so good so far. You must give us a tracklisting! |
Is this made using Atomix???????
Greetz, ikke PS: nice job! |
Can anyone PLEASE tell me the name of the last tune in Syfoon's mix?! PLEASE! |
WOOOOOOOOOOO relaxed !!!!!!!!!!!!!!
Go girl go girl YEAAAAAAAAAAAAH this song rockss |
Dude, this stuff rocks!
How did you do it? I'm a professional DJ in the Netherlands but I never heard such fine mixing. Keep up the good work.... |
Simple, I've been doing it a looong time :)
- Bren (Syfoon) |
