Forum: Music discussion
Topic: how to increment tracks when mixed ???
hi all , as usual i`m pickin` brains again lol, anyway , after mixing and burning onto cd , it comes out as 1 track , so the question i need to ask is , can i get hold of software that will increment the tracks before i burn them....
thanxs to you all ......mark
geposted Sun 17 Mar 02 @ 3:46 pm
ikkeHome userMember since 2003
You've got to record your mix as multiple wav files, by using the scissors symbol. Afterwards, you have to burn all these wave files to your CD (in the right order off course!!! ;))
geposted Sun 17 Mar 02 @ 4:24 pm
Ikke , you are a saint, took your advice and it worked a treat , seemless mixing, who knows , with your help i may get the hang of this thing....thanx a million , the cheque is in the post ;-)))))))))) ...regards mark
geposted Sun 17 Mar 02 @ 11:53 pm
Abou that cheque: 500$ is enough ;)
geposted Mon 18 Mar 02 @ 6:13 pm
sorry ikke, have already made it out in £`s...is that ok lol
regards mark
geposted Mon 18 Mar 02 @ 10:38 pm
sblondyHome userMember since 2001
An easier way is to use easy cd creator, which has the option to place track-marks wherever you want, without editing the original wave file. I don't know any other program that can do this, so if you don't have it...
geposted Tue 19 Mar 02 @ 7:43 am
Pounds, $ or €, I don't care! ;)
geposted Tue 19 Mar 02 @ 5:00 pm
Ikke ... don't forget when I said I'd sponsor you one of these days !
geposted Tue 19 Mar 02 @ 5:02 pm
??? Are you serious??? What do I have to do for that?
Wow, I almost fall of my chair ;)
geposted Wed 20 Mar 02 @ 2:48 pm
thanx peeps think i have mastered the problem now , but the input has been most appreciated...cheers
regards a much wiser mark
geposted Wed 20 Mar 02 @ 6:29 pm
