Can i use only one "SoundBlaster Audigy Platinum" if i want two seperate channels to my mixer? or do i need to buy two of them?
plz help
plz help
geposted Fri 06 Sep 02 @ 1:25 pm
You don't need a second soundcard. Sound Blaster Audigy already has 2 stereo audio ouputs. One for front speakers and one for rear. All you need to do is enable 3D Soundcard and Mixer in the configuration of Atomix, and make sure your rear speakers are enabled in the Sound Blaster control panel.
geposted Fri 06 Sep 02 @ 6:52 pm
Thx for help m8!!
geposted Fri 06 Sep 02 @ 10:07 pm
