Forum: Hardware Technical Support - Topic: About the CUE Points
Questions or comments about the supported hardware by VirtualDJ, Numark Cue, Virtual Vinyl or AtomixMP3.
For general troubleshooting and MIDI controller configuration, please see Config & Troubleshooting.
Hardware products
VirtualDJ Forum
Hardware Technical...
Autor - Topic: About the CUE Points -
Nicococo
No license user
Posted Tue 20 Jan 04 @ 6:44 pm
Hello,
I didn't find a way to go to Cue Points "on the fly" with the Dj Console.
With the keyboard shortcuts I can easily go to CuePoints without stoping the music.
No way to do that with the DJ Console. Once the Cue Points are set, the music stops when I hit the 1, 2 or 3 button on the Dj Console. I have to press "Play" again. You see what I mean?
Thanks!
levalere
Limited edition user
Posted Sat 07 Feb 04 @ 2:20 pm
i have the same problem ... and even with reconfiguring the DJMapper .. it doesn't works
vantinedj
Experienced pro user
Premium Member
Posted Sun 08 Feb 04 @ 9:35 pm
It does not work. I just click on the screen.
DJCannonball
Posted Mon 09 Feb 04 @ 11:57 am
i see what you mean. i haven't figured it out yet, but i think it is not possible (yet) in current version.
i'll have a look when i'm home.
