is there an effect that i can use to get a reverse beat?
geposted Sun 10 Nov 02 @ 6:54 am
This is rather simple to code, so can you give a slightly more extended description of what you need exactly.
Like frequency, duration, how would you like it to go from the original song to the effected signal ?
Important : playing a beat reversely is possible, but based on a sample since you cannot read ahead in the audio stream sent to the effects engine.
Rgds,
DJ Corpse
Rgds,
DJ Corpse
geposted Sun 10 Nov 02 @ 7:56 pm
i basically wanted to turn a beat in the song around or at least distort it so it sounds that the beat is reversed.
i would also like effects that more closely resemble those found on the pioneer EFX-500 effects generator. to date, my favorite effect for atomixmp3 is the flanger, but i would like possibly adjustments for it? any input helps, thanks
geposted Wed 13 Nov 02 @ 1:52 am
