I have no experice as a dj. so i want to know, is it possible to remove the beat of a song, so that you just can here the vocals?
Kind regards LilNil
(if there are any mistakes in my english, I have to apologize, I'm from germany)
Kind regards LilNil
geposted Thu 22 Jan 04 @ 2:46 pm
You can try to cut the bass and the Hi , but it isn't very good
geposted Thu 22 Jan 04 @ 5:54 pm
i know there is a plug-in that is supposed to remove vocals for VDJ
geposted Thu 22 Jan 04 @ 8:35 pm
Only for the beat i can also set the loop at right place. But I want to mix two songs, and therefore i only need one beat but two vocals, you know? Kind regards LilNil
geposted Thu 22 Jan 04 @ 8:40 pm
Ok, this ones a tricky one. There is only one way to do it as I know and it isnt pleasent.
As you may know most songs are recorded in stereo. Now, some songs have the vocals recorded in a single channel of the two, therefore by using some kind of phase inverter, flanger or other trickery it is possible to remove the vocals. But it isnt that effective.
Now you say you want to remove the beats. Well there is certain software on the internet that once removes the vocals lets you keep the vocal channel/layer and loose the beats using the same method but discarding the downmix.
I have tried using these softwares and it all depends on how the track was recorded. If you have stereo vocals then no good. I am quite suprised that it is not possible yet because as you know for a human to distinguish between vocals and beats is possible. So why not a computer?
Anyway, the best method for you is to search for the acapella versions if you want to keep vocals, or instrumental and karaoke versions if you want to keep the beats. Bearing in mind that it will be quite hard if not impossible to find these for certain tunes.
If all else fails, buy the sheet music and use a programme such as fruityloops to recreate the tune. This also has the benefit that youre not breaching copyrights.
Jukesy
Jukesy
geposted Fri 23 Jan 04 @ 1:40 am
LilNil, to isolate the vocals.. turn down the bass and treble.
vocals are at mid-range. There is no way filter this for 100% even expensive equipement can't do that.
you can only surpress beats a lot, but not completly
and Sharan, LilNil is trying to filterout all other sounds so that only the VOCALS remain (instead of removing the vocals).
geposted Fri 23 Jan 04 @ 7:54 am
I am very thankful. I got some acapella tracks, but not the one I need. If it's possible to remove the vocals, why is it impossible to remove the beats? Maybe I have to ask in a music- store for software like that. Kind regards LilNil
geposted Fri 23 Jan 04 @ 11:35 am
it's easyer for an equalizer to surpress frequencies for vocals because vocals mostly contain tones which are nearby 1khz frequency. so it's easier to isolate and surpress those frequencies.
Drumming beatz frequencies make use much more frequencies including from low frequencies (basskick) to high frequencies (hihats/snares). vocal-frequencies are somewhere in de middle of the audio-frequency-spectrum.
so, it's almost impossible to filterout/surpress beatz out of a song.
geposted Fri 23 Jan 04 @ 1:10 pm
Hi LilNil
ive been doing a bit of research for you and Ive found these:
http://4trak.net/dsico/archives/000082.html
and
http://gybo.proboards4.com/index.cgi
should keep you busy for a while
and
geposted Sun 25 Jan 04 @ 9:23 pm
