I haven't been able to boot atomix 2.2, it does the little intro window then disappears. Yesterday I had a DirectX error msg, anyone have any ideas what it could be? Atomix 2.1.1 worked, maybe my drivers are corrupt?
geposted Sun 05 Jan 03 @ 5:11 pm
This should solve it.... go to the DirectX web site and down load and install the latest DirectX drivers. Make sure you have your antivirus software and fire walls turned off when you do this. Leaving background programs running while installing DirectX can some times corrupt the files (to feel safe about your download...you can always scan the file for a virus before you extract it and then turn off all background programs) This should help. Also, re-boot after you install them then try to re-load and re-start atomixmp3.
Hope this helps.
Hope this helps.
geposted Sun 05 Jan 03 @ 5:15 pm
