alright guys I need to know how to create advanced shortcuts. For example on the 700s skin there is an option to rewind to cue point but there are 5 I'd like to assign each to a key on the keyboard for some advanced beat juggling and help would be greatly appreciated :)
geposted Thu 05 Feb 04 @ 6:07 am
Ok, try this:
First you go to shortcut in VDJ option, assign a key (ex: 1) for the first shortcut:
1- Press key “1” to assign a key
2- Click on “add” and choose “go to cue”
3- In value choose “1” (1 is the number of the cue)
4- Save it
Now when you press "1" the song go to cue 1 and play. Repeat the command and choose another key (ex: 2) and “2” in value for cue 2…
If you want: Go to cue and stop, you can add a shortcut "stop" at key "1" . Just remember VDJ make the action in order you enter the shortcut for one key.
Example, in this shortcut (key"1") VDJ make: Go to cue 1 (play by default), stop (if you add this action)
Hope this help :-)
Coyote
4- Save it
Hope this help :-)
Coyote
geposted Thu 05 Feb 04 @ 6:51 am
Thank you sooooooo much! if they only knew with this program could do!
geposted Thu 05 Feb 04 @ 7:08 am
