i am having a problem with the crossfader not going
completely to the other player when i have the settings set to mix at beginning and mix on end this causes problems with the volume not being full. when i have it set to last beat it mixes way to early at 45 seconds.
geposted Sat 22 Mar 03 @ 11:35 pm
The automix function is not perfect... There are a lot of reason:
- local bpm not regular
- bad setting
For a good mix you have to mix manually by yourself: you will discover that it is better than make automix mixing itself!
Enjoy
Peroz
- bad setting
Enjoy
Peroz
geposted Sun 23 Mar 03 @ 1:02 pm
Try to disable autogain.
For the rest i agree with Peroz.
Greetz,
Salva
Greetz,
Salva
geposted Mon 24 Mar 03 @ 9:20 am
