..So that i can skip between different tracks ? I have Nero.
geposted Sat 05 Apr 03 @ 9:05 pm
if you record using the atomix crossfader (not an external mixer) you can select the "auto cut" option in the "record" tab
geposted Sat 05 Apr 03 @ 9:58 pm
That will not cause any interruptions in the music ? If this is the case, it s cool !
geposted Sat 05 Apr 03 @ 10:03 pm
no there will be none at all and you will get separate files e.g mix001, mix002 etc
geposted Sat 05 Apr 03 @ 10:06 pm
Ok I just made a new mix using the cut feature of Atomixmp3 and it's cool. Thanx for your help.
geposted Sat 05 Apr 03 @ 11:54 pm
no worries thats what i'm here for :)
geposted Sun 06 Apr 03 @ 2:19 am
you can use "cdrcue cuesheet editor" its a small program that put marks in a big wav or mp3 file and export an image that can be burned with nero easy.At the end you get the cd with tracks 1.2.3.4 etc
in this way
program: http://www.dcsoft.com/prod03.htm
for nero: http://cj-dimitrist.tripod.com/cjdimitristofficialsite/id20.html
in this way
geposted Sun 06 Apr 03 @ 11:27 pm
