Forum: Hardware Technical Support - Topic: help with the console doesn't switch into dj-mode
Questions or comments about the supported hardware by VirtualDJ, Numark Cue, Virtual Vinyl or AtomixMP3.
For general troubleshooting and MIDI controller configuration, please see Config & Troubleshooting.
Hardware products
VirtualDJ Forum
Hardware Technical...
help with the...
Autor - Topic: help with the console doesn't switch into dj-mode -
jamsaver
No license user
Posted Mon 16 Feb 04 @ 9:44 pm
Hi all...
I just updated my vdj and console and realized i can hear the playing song whether i switch into a different channel.
I mean while i was playing in the first deck "the headphone light is on" i press the other one (to listen the incoming song)
but i still hear the music from the 1st one ?
i couldn't find a solution to this i didn't have a prob. like this before the updates.
Thanx
Jam
DJOlive
No license user
Posted Thu 19 Feb 04 @ 8:58 am
Jam,
With the DJconsole Version,When you press the headphone button, the sound is sent to 3/4 outputs ( back of the console ), but the sound is also sent to 1/2 depending on cross-fader position.
In the DJconsole Mixer you have a button (Audio Mode ) that switch the physical headphone ( front of the console ) output either to 1/2( Standard ) or 3/4 ( DJ ).
Hope it helps you.
