Topic: Any one use atomix with arabic title ???
i need some help concerning the atomix software which is that this software is great, but doesn't support unicode.. so i can't read any of my music files and shows rubbish letters instead of showing me the title in atomix in arabic..i'd like to have some help from any of the atomixmp3 developers asap or any suggestion from any user will be appreciated..
regards,
samira
geposted Tue 27 May 03 @ 9:48 pm
mixalisPRO InfinityMember since 2003
This way it works with Greek Language and sould work with any other.
For w2k or winxp
Go to atomixmp3 folder and find thw subfolder named skins.
Open with notepad the skin xml file that you want to use and supporting arabic.
Replace - tahoma - font with a font name which support arabic characters. (Like - arial arabic - )
Save the xml file, open atomix and load the skin that you modify.
geposted Wed 28 May 03 @ 7:26 am
ns-codeHome userMember since 2003
I've got the same problem with cyrilic in Serbian and Russian. I still think it would be better to fix the program than to offer go-arounds.
geposted Fri 30 May 03 @ 8:28 pm
samooHome userMember since 2003
Hi Samir
i am a D.J from lebanon 2 .
i was having like your problem with "Atomix, Bpm, and another mix software".
you can make it easy when you copy your music at your pc, you can rename the file like (sa7arni / najwa karam) , with the rename of file you can use't with any mix software programing like atomix or bpm or another programes without a problem .
D.J Samo Lebanon
geposted Sun 01 Jun 03 @ 5:37 pm
