Forum: VirtualDJ Skins
Topic: default skin at 1024*768
hi, is there any place i can get the default skin but at 1024*768 resolution?
geposted Sat 07 Jun 03 @ 6:04 pm
The fact is the skin is only available in a 800x600 resoulution because (well i don't know if this is true but I feel this way) it's like a demo skin that just gives you a taste of atomixmp3's power and would be more applicable If there were more features but It's main purpose was an easy look at atomixmp3's features. It makes them obvious and attracts the users with it's user friendly easy interface. The fact that it makes it smaller and takes up less screenspace makes it perfect for mixing while surfing the net or doing something else...not designed for mixing at venues or clubs....
What I would suggest is to just go to the skins page and click on 'show all submissions' there maybe be some modified default skins that perhaps may be in 1024x768 resolution but if not well...YOUR SOL
(shit outta luck)
So there ya go!!!
(sry for not responding as quick as I usually do...Funfilled weekend!!!)
geposted Mon 09 Jun 03 @ 3:23 pm
DJ CocoPRO InfinityMember since 2003
your right XxNuMbR1StUnNrxX !
geposted Sat 14 Jun 03 @ 6:26 am
loujrHome userMember since 2002
i could try to make default at 1024*768 and then submit it
geposted Thu 28 Aug 03 @ 3:37 pm
