hello...
my harddrive in my laptop was corrupt recently and after just having my laptop returned i have just reloaded the atomix program back on. i have also had to reinstall all my music.. but now i have just disscovered that when i try and enter the program... which i have only just put back on.... i can't get into it as it pops up "the internal database is corrupted".
please help me get back into it as i would like to be able to use what i paid for!
thanks Paul.
thanks Paul.
geposted Sat 12 Jul 03 @ 6:26 pm
you need to make a new internal database!
if you have a copy of the database (highly reccomended you save a copy every so often) just copy it into the atomix folder, if not then you have lost all your bpm's and gain levels and will have to try reinstalling again or delete the internal database
geposted Sat 12 Jul 03 @ 7:07 pm
in this case,m rather than un-installing and re-installing again. Look in your Atomixmp3 folder, and fild the file named...
atomixMP3 Internal Database Delete that file.
then re-launch Atomixmp3.
geposted Sun 13 Jul 03 @ 3:21 pm
