Forum: Old versions
Topic: Cannot Cue
nancybPRO InfinityMember since 2004
Help, I have used herconsole many times with v 108vdj. ALl of a sudden I cannot hear the cue in my headphones. I have the hercules selected as sound card and am using the DJ setting. ANyone else have this problem?
geposted Sun 22 Feb 04 @ 8:56 am
i'm not sure i understand you. it did work before, but suddenly is doesn't? maybe you have switched to another skin.
The pioneer skin has some sliders which have influence to your headphones. For me, it never worked before. i have faith they will fix this issue in the first next version.
geposted Tue 24 Feb 04 @ 11:48 am
