I've downloaded the demo version and I really like the program so I'm considering of buying AtomixMP3!
I have 2 questions and hope somebody can help me out on this:
I've scanned my local drive with extended analysis and when I search for a particular song Atomix finds it for me. But when I try to load the song from the search-field into the player it won't work. When I load the same song from the file browser then it plays correct. (I didn't replace the file since the scanning of all files)
My second question is if it's possible to keep a song in the playlist after it has played, because my playlist is getting shorter and shorter and shorter and shor.... ;-)
Thanks
Elvos!
Thanks
Elvos!
geposted Mon 29 Sep 03 @ 2:54 am
chances are that the song you found in the search probably had been at least slightly re-named. You must re-scan your hard drive every time a file is renamed or deleted.
geposted Mon 29 Sep 03 @ 4:33 pm
Yep, you're right!
I've scanned my hard drive again and it works!
I'm glad that I didn't needed to re-scan with extended analysis again cause that took me a couple of hours...
Well, thank you very much for your help ;-)
Greets,
Elvos
Greets,
Elvos
geposted Mon 29 Sep 03 @ 4:53 pm
