Topic: Update!
Well do anyone think or know if we will get any updates for Atomix? anyone know??
Cheers.
geposted Fri 31 Oct 03 @ 4:44 pm
DJ RickPRO InfinityMember since 2003
What do you think needs to be updated?
It's pretty darn good software just as it is.
geposted Fri 31 Oct 03 @ 6:51 pm
this is an update on all the former updates....those updates no longer apply as this update updates all the other updates that were updated here.if your new update does not work don`t worry. someday there will be another update to fix this update and the new update will update your system so that ALL up dates will update and work fine with your new update.and if that update refuses to update all your other updates then try this update:if you want to go on an up date buy an airplane ticket and take your significant other up on a date....that will be an update that will work for sure.
happy updating
geposted Sun 02 Nov 03 @ 5:31 pm
In other words.... No!!
geposted Tue 04 Nov 03 @ 12:09 pm
