Forum: Old versions
Topic: brake effect
anyone have a problem with the song randomly stopping as if you engaged the brake effect, but didn't?
geposted Sun 29 Feb 04 @ 5:27 am
I have had this problem once or twice I think it could be something to do with the hypersensitive jog dials. If it does it all the time then I would send it back to Hercules (dont hold your breath waiting for it back.
I have also noticed that you have a problem a bit futher down the list in this forum about your FX button flashing. This could mean that the flashing means the button may be stuck and then if you have the brake effect selected at the same time would cause the music to stop.
Thanks, I'll check it out
