Inorder to use the headfones in atomix, u need 2 soundcards?
or can u just use one??? becuz i have a problem with having 2 soundcards, one which is on the motherboard (integrated)and other which is soundblaster 5.1. Whenever i would listen with the sound blaser, the music will lag (skip) alot, so i need help
thx for your tyme =)
geposted Sun 09 Nov 03 @ 9:06 pm
In order to use headphones to listen to one deck, while the other plays through your main speakers, you must have the full version. 2 seperate outputs is not available in the demo. And, indeed, it can be done with only 1 sound device.
geposted Sun 09 Nov 03 @ 11:03 pm
