I just started to download some skins for my atomixmp3 and i can't load the skins. what do i do?
thank,
spincykle.
thank,
spincykle.
geposted Tue 27 Jan 04 @ 11:33 pm
Does anyone know how to load the skins to atomix??? i desperately need help!!!!!!!!!!!
geposted Tue 27 Jan 04 @ 11:36 pm
I will tell you how I did it.
1. went to windows explorer, program files, atomix (filefolder) inside there is a subfolder called skins. You can copy & paste what you downloaded to that file.
2. go to the atomix program, after loaded, right next to the record botton is a ? , click that botton , that is the options botton, that will open a screen that you can chose (change skins) then it will load
Djspice
Djspice
geposted Tue 27 Jan 04 @ 11:59 pm
Extract to the download page:
"To install a skin, unzip the .zip file (using a zipping utility such as Winzip), and copy the files in the c:/program files/AtomixMP3/skins/ directory.
You can select it from the "skin" item in the configuration page of AtomixMP3."
Please read the instruction...
Coyote
Coyote
geposted Wed 28 Jan 04 @ 2:22 am
