Forum: Old versions
Topic: fader keyboard shortcut help
hi all, im tryin to create shortcuts for the 3 EQ faders....but when i make one and use it it insanely stutters VDJ....i use the default one for theregular crossfader all the times and no problems
i wanna make it for keys
E-R (high)
D-F (med)
C-V (bass)
and ive tried different values and nothing seems to work w/o VDJ spazzing out...any help??
i run a XP p3 w/ a 3d yamaha sound card and this is the only time VDJ stutters - thanx
geposted Thu 04 Mar 04 @ 5:33 pm
you just have to put the value (-128) for the letters E,D,C
and (+128)for the letters R,F,V
But The letter "R" is already used for record, you should choose another combination
that was my problme...using R...thanx!
You can use "R" key for what you want:
In shortcut panel, click on record and delete it (you can assign another key for record)
Now you have an “R” key clean for your shortcut :)
Coyote
