Forum: VirtualDJ Skins
Topic: Minimax 1.0 1280x800
Hi all,
the new skin Minimax is now available in skins section.
Feel free to alter logo of the browser background.
To close the virtualDJ use the ALT+F4 combination.
Don't forget to install the included font "LCD.ttf" in order to look ok.
It's intended for use with hercules or other controller.
When you right/double click under the author name you can alter the comment.
EQ's were originally meant just to show the value, but current skin doesn't allow it so therefore
the sliders.
Any comments are welcome.
Future plans (soon):
correct the bug of overlapping left deck text with the equalizer.
New resolutions (post here which are desired).
Indication of "BEATLOCK" :-) engaged
geposted Thu 04 Aug 05 @ 10:28 am
I would like to use this as my default skin, but I found 2 small bugs so far.
Top right buttons
SAMPLE - opens Record Menu
RECORD - opens a Blank screen
Aside from that it's pretty much what I need, big easy to read display, clean and to the point. Nice work man
