Forum: Old versions
Topic: Sound Configurations in Demo version of VDJ
Attention No License Users
The sound config in the demo is locked to only one output. This means no "headphones" or The ability to prelisten to tracks. Consider This a limitation to the demo version. From This Point forward a post asking "why no Headphones" or "advanced sound config not working" by a NLU will be removed to make room for other topics in this section.
Time coded demo users note:
Due to the sound config options, you may only use 1 time code for testing puropes
Crack Users Note the following:
Most crack copies of virtual dj are just an unlocked version of the demo, so this means the headphones will not work there either.
Thanks for understanding.
geposted Sat 06 Aug 05 @ 4:04 pm
