Can anyone tell me why my CUE level is always higher than the MASTER level on my Phonic MX300 mixer? If i turn the gain down on the channel the MASTER also reduse. The treble mid and bass is all in centre, but if i play the same song on both CUE and MASTER the CUE is higher.
I hope i wrote so u understand the question... Tell me if u need more info.
Fl@me
PS: The one channel of the 5.1 conf. (back speaker plug) i run is louder than the other, what can i do to equel them to the same gain on the pc?
Fl@me
geposted Sat 20 Aug 05 @ 9:29 am
The reason the speaker plug has a higher volume is so that you can get a surround sound with a 5 speaker system. If you are using these plugs as a way to preveiw your tune that you have queued up, then it will be either louder, softer or the same, depending on the purpose of the plug you are using.
I hope this helps out. If anyone else knows more, please post as I maybe way off
geposted Sun 21 Aug 05 @ 5:36 pm
