Forum: Old versions
Topic: Video format / quality? - Page: 2
That is the sample rate in the audio stream. Since some of the newer DVDs are going with that do you know if there is a way to play them in VDJ? Or will they address it?
You could play it, but notice this issue in the audio a few days ago. The VDJ Team is working in it. The video most be good. If it doesn't maybe we're missing something.
change .vob to windows media audio decoder, then use the nvidia dvd decoder as your codec.
Michael Jackson Live in Bucharest from 92. Just released I think. Killer DVD. He is obviously a troubled person but I have seen him live once and it's an incredible experience. Your mouth drops open when you see him walk out. Absolutely breathtaking. This video is a must have. Thriller, Beat It, Billy Jean, Man In The Mirror, etc--all live with excellent choregraphy. And yes he does the moonwalk on Billy Jean. The best Billy Jean I've seen was on his 25th anniversary special. But I don't think that is on DVD. Live tv show.
I will try DJ Cyder's suggestion and report back. THANKS ALL!!!
I changed .vob to the wmp audio decoder but how do i change the codec to nvidia dvd decoder?
OK I looked it up and it loooks like you mean for me to install the nvidia dvd decoder plugin for windows media player. Would I select it as an audio DSP in WMP?
Is that the only way to play these vob's in VDJ. It's a $50 plug in.
Thanks
Just bought that MJ dvd for $9.95, shipping next week though.
I played Smooth Criminal from it last night and a crowd gathered in front of the screen and you couln't see. Incredible.
The fastest mpeg codec (with low CPU usage) is Elecard. I have't tried yeat with VDJ, but have used it in other application with great result.
Install the player and you get the codec, the player is only $20
http://www.elecard.com/products/mpeg2player.shtml
I ment windows media video decoder doh! The way I told you about is the fastest was as it uses the gpu on the video card, the internal decoder should play vob's mine does. Do you have msn I could help you in real time then, my msn is in my blog. The nvdecoder has a 30 day trial you could test it before.
Sorry...
DJ Cyder: Ill try the plugin suggestion and I also added you on MSN. That plugin is a bit more complicated than I thought LOL.
