Currently the time code setup information is stored in the registry. It is possible to store just 1 setup.
I use timecode with vinyl or my cd players depending on the gig. Due to this i have to setup the timecodes before starting the gig.
I would like to have the following changes addition:
Move the Timecode settings information from the registry to an XML file. Also make it possible to store more than 1 setup.
With this change you have the option to:
- Copy the setup easily from 1 pc to another, While xml is easier to copy than registry settings
- Make settings for more than 1 setup. If you could give a certain setup a name like 1200s, or Denon cd players, you could switch from 1 setup to another
This will speed up the setup before a gig and is less stressfull.
Ewout
Ewout
geposted Sun 28 Aug 05 @ 8:58 pm
