Im building a new video mixing box and am curious what everyones running for motherboards.  I usually run Intel desktop boards but am open to suggestions.  I'll be running one of these two video cards.  Havn't decided which one yet.
http://www.newegg.com/Product/Product.asp?Item=N82E16814130240
http://www.newegg.com/Product/Product.asp?Item=N82E16814135171
geposted Wed 14 Sep 05 @ 12:13 am
          I am currently running an ASUS P5AD2-E Premium motherboard. It has a PCI express 16x for a blazing fast video card. Support for three hardware based RAIDs and much more. I have been using this board for 3 months and have no complaints and best of all it can be overclocked from the windows environment. http://usa.asus.com/products/mb/socket775/p5ad2-e-p/overview.htm
    geposted Wed 14 Sep 05 @ 5:37 am
          Here's a combo offer worth considering:
http://www.mwave.com/mwave/Skusearch.hmx?scriteria=bk00011
geposted Wed 14 Sep 05 @ 11:29 am
          Look these:
$235 Chipset 955X
http://www.newegg.com/Product/Product.asp?Item=N82E16813121286
$122 Chipset 945P
http://www.newegg.com/Product/Product.asp?Item=N82E16813121288
Check this too:
http://www.virtualdj.com/forums/14111/Hardware_Technical_Support/PC_Setup_for_VJ_ing_--_How_about_this_.html
I recommend you a 640 Intel Processor, but buy what you could affort, I have a 540 and it's very good. The new processors support 64 bits extension support (EMT64) and have a one in the end (541, 531, etc) and all the 600s series too. (The top off the line is the Intel Pentium 840 EE)
http://www.intel.com/products/processor/pentium4/index.htm
    $235 Chipset 955X
$122 Chipset 945P
Check this too:
geposted Wed 14 Sep 05 @ 5:58 pm
          The memory modules I suggest are DDR2. You could use 533 or 667 DDR2 memory modules. 667 is faster than others, and use a pair of memory modules to get your full mem. If you want 1GB use 2 512MB 667 DDR2 modules, for 2GB use 2 1GB 667 DDR2 or 4 512MB DDR2 modules.
The main change in 945PSN and 955X is the matrix storage technology included in 955X and in some 945 like 945PVS http://www.intel.com/design/motherbd/vs/vs_available.htm.
This tech will protect your information in case one HD fails. http://www.intel.com/design/chipsets/matrixstorage_sb.pdf
geposted Wed 14 Sep 05 @ 6:36 pm
