Hundred gigs more.....
4th drive to go into this 3U chassis.
One 300 on the right front, one 500 left rear, and 2 250's under the DVDRW all SATA drives.
http://www.imagestation.com/picture/sraid187/pc2d65deed5718c9e18d89e300ebf7a7f/f249bc17.jpg
That will give me 1300 gigs total, lets see how fast I can burn that up.
geposted Fri 16 Sep 05 @ 1:31 am
mp3rick --
get this error on your link --
Forbidden
You don't have permission to access /picture/sraid187/pc2d65deed5718c9e18d89e300ebf7a7f/f249bc17.jpg on this server.
Oh, to answer your question on burning up 1300Gig
About 140,000 mp3 / mp3+cdgs and 20,000 video files
Forbidden
geposted Fri 16 Sep 05 @ 1:55 am
Well 1 of my new Dell servers has just gotten a (6) x 300GB SATA RAID array installed. It's only 1.5TB but man it's nice. Fortunately my music collection only hovers around 125GB and music video collection is at about 240GB so I will keep Djing with my little 250GB USB drives for now :-)
geposted Fri 16 Sep 05 @ 2:04 am
Not sure what's up with that, it happens now and then.
It won't even let me in with that link, and I am certainly authorized.
I'll check it again tomorrow and repost it if it's still dead.
geposted Fri 16 Sep 05 @ 2:44 am
The file is physically there on the webserver. The header reports the file is there with a modified date of today, along with a content length of 27,614 bytes. So the file is defintely there. This is apache webserver runing on Unix so it probably has a permissions problem with the file. If you have a shell account to log into the server do that and run:
chmod og+r pc2d65deed5718c9e18d89e300ebf7a7f/f249bc17.jpg
If you don't have a shell account and uploaded the picture with some web interface or something, then the server is most likely misconfigured with a bad "Allow" line in the main configuration file or an .htaccess file in the image directory.
geposted Fri 16 Sep 05 @ 3:29 am
Ta Dahhhhhhh!
And today it's working!
Simply amazing!
Simply amazing!
geposted Fri 16 Sep 05 @ 11:55 am
Rick;
Just tried it. Still get this msg:
Forbidden
Forbidden
geposted Fri 16 Sep 05 @ 1:29 pm
Yup, it's doin' it again....
geposted Fri 16 Sep 05 @ 1:55 pm
Top left photo shows the drive placement.
https://virtualdj.com/blog/mp3jrick/
By the way for you builders, silicone mounts hold these drives perfectly positioned and shock mounted.
I have 2 stacked with silicone and 2 mounted to surfaces all mounted inline with the cooling airflow.
Love the SATA drives and the loss of the ide ribbon cables, it just makes it soooo neat.
This unit also has a 475W power supply for anybody who might be wondering.
geposted Fri 16 Sep 05 @ 9:32 pm
