i am looking for a button which opens a small window where i can put some songs which i like to play or not. so if you go on autoplay you don*t have to search the songs again. Maybe a textbox where you also can write down some information like annoucments (somebody should put his car away the number is....., or somebody's birthday ......
So you always can look in this textbox if you need too.
geposted Sat 17 Sep 05 @ 8:05 am
If i got what you said right (with my bad english) U want a notepad in VDJ... Many persons have talked about it before... I don't remeber who said it, but i agree with them, a notepad in VDJ will be usefull...
geposted Sun 18 Sep 05 @ 1:47 pm
Michaela, i agree with U, a wish list (not just a notepad) would be usefull, but i think you can use the playlist in the right side of browser (i don't use it as a real playlist).
Anyway can you tell me which controller are you using? I saw one in your blog (really nice). Can you give me a link ?
geposted Thu 22 Sep 05 @ 3:27 pm
The controller in his blog is a D-Vinyl 2020 from Soundgraph...I'm not 100% sure but I think they may have gone out of business so Ebay may be your best bet.
It does have a built in Sound Card and was designed to work with TCCD + TCV, there own Time Code but you could switch between the hardware controller and Timee Code on the unit.
I almost bought one when they came out but at the time I thought £700 was quite dear.
Ross.
Ross.
geposted Fri 23 Sep 05 @ 10:15 am
It's the D-Vinyl 2020. I still have support on. http://www.d-vinyl.de or in english
http://www.soundgraph.com/wwwroot_d-vinyl/index.shtml
geposted Fri 23 Sep 05 @ 7:07 pm
