Forum: Old versions
Topic: TCCD Cue Points
Hey Everybody
I have recently set up my Dennon 1800 to use Time Coded CD's. I have it set up properly with the Maya44 usb card. It works but I have a problem.
The problem is that I cannot properly set my cue points. I have tried manually doing it with the mouse and using the Dennon jog wheel to set the cue point like I used to do when I was mixing with regular CD's. I can set the point either way but when I press play to begin mixing the song goes right to the beginning and starts from there completely ignoring the cue point that I have set. Also when I am playing a song using the TCCD and I press cue the song does not go back to the cue point but it just pauses. Is normal for TCCD's? Should I have just bought a DAC-2 Controller instead?
What amI doing something wrong? Am I missing something a setting perhaps? Has anybody else experienced this problem?
Any help would be greatly appreciated!
Peace
JumpinJim
geposted Wed 28 Sep 05 @ 3:15 am
Nobody has any suggestions?
I have a Denon 2100F but I use TCVs... let me check and I tell you. Some fellows have some issues, but can tell if you are doing wrong. We could check. Disable "Time Strech", and the "Limiter" too. In your Denon don't use Master tempo.
I have reported simillar problems many times.
What i want is (like you) to use the virtualdj stored cues and cd-player's control for start/stop/pitch etc. A needle drop bypass may be the answer.
Let's hope for a fix.
I have actually the same problem with last version 3.4..
My config:
VDJ 3.4 + 2xDenon dn-s1000 + dn-x100 + Maya44 usb
@kunfufaiter, cd timecode mode is 100% improved in latest official 3.4
Only some small problems left.
I can use the cue points and more.
i have vdj 3.4 DEMO and it's not working for me...
wich config have you got?
extra config is needed?
I'm very interessed about this...I'am wainting to resolve this issue to buy the full version....
