Forum: VirtualDJ Skins
Topic: Which SKIN the BEST?
igarokHome userMember since 2005
What do you think?
geposted Thu 29 Sep 05 @ 2:52 am
bagpussPRO InfinityMember since 2003
Good question, of course it's entirely preference.
1) Pioneer CDJ700's
2) Mixstation
3) Default
4) Red VRM
I believe the most popular custom made skin is mixstation.
geposted Thu 29 Sep 05 @ 3:08 am
frd1963PRO InfinityMember since 2004
JN-Black fits my purposes almost as if it were custome made to my specs ! ;)
geposted Thu 29 Sep 05 @ 5:48 pm
acw_djPRO InfinitySenior staffMember since 2005
I like the Advanced Default skin a good one, and the Denon White too. But I still working with the default skin... I have to do one to cover my specs.
geposted Sat 01 Oct 05 @ 6:28 pm
DjZexaHome userMember since 2005
Defult
geposted Sun 30 Oct 05 @ 1:31 pm
I think it may depend on what your most comfortable with. I cut my teeth on Techniques 1200's and Rane mixers. I slipped into the default skin like an old pair of jeans. I suspect anyone who started DJing with CD's would gravitate to another skin for the same reason.
geposted Sun 30 Oct 05 @ 3:54 pm
dj_cashPRO InfinityMember since 2004
Pioneer S700's
geposted Sun 30 Oct 05 @ 8:41 pm
HaywardPRO InfinityMember since 2005
Default
Mixstation
For me its very important that the buttons are in the right place.
I think DJJB skins are good except that the 'sync' buttions should be on the mixer, next to each other.
In my opinion John's skins are of excellent quality but the 'sync' buttons are always in the wrong spot and during live mixing I have spend too much time trying to find them.
geposted Mon 31 Oct 05 @ 3:20 pm
djjbPRO InfinityMember since 2004
hello hayward
didn't know that it is so hard to find them...i will change this for you.
(hope to see a picca of it while your playing a gig)
geposted Tue 01 Nov 05 @ 8:24 am
updated today 01-11-05
pitch bend for each player.
sync-buttons in mixer.
geposted Tue 01 Nov 05 @ 9:40 am
Thank you DJJB, you are the greatest and so are your skins.
geposted Tue 01 Nov 05 @ 3:49 pm
don't know what's goin' on here but the advanged default skin is gone after the update..
maybe someone from vdj can answer me.
geposted Tue 01 Nov 05 @ 8:07 pm
Everyone should give DJJB's new advanced skin a try. It's got everything you need at your finger tips and the colors are perfect. My new choice in skin is this one.
Excellent work!
geposted Wed 02 Nov 05 @ 5:28 pm
vpcdjHome userMember since 2004
djzero's Darkfun Blue V2.01
its easy on the eyes.
if possible i'd like a 800X600 version of this skin.
geposted Mon 14 Nov 05 @ 7:38 pm
@djjb:
Dude, you are freakin awesome!! Your skins are the best! The only thing I can think of at all to improve would be to lose the red on the side of the turntable and maybe make it so you can change the gain by clicking on the number (like with the equalizers).
It took me two minutes to clear up the red on the side of the turntables, I'll send you a pic to your email so you can just copy-paste it in if you like.
Thanks again,
Steve
geposted Mon 28 Nov 05 @ 9:50 pm
@djjb:
Oh, I remembered one other thing that I found... When you use the visual that shows the actual output, sometimes there are grey markings that show just between the visual and the wave form. I suspect that this is because the actual output is higher than the visual has room to display and therefore goes too high. It's not a big deal, but I think it would be pretty easy to fix.
geposted Mon 28 Nov 05 @ 10:22 pm
it's a bug..
geposted Tue 29 Nov 05 @ 1:38 pm
I fixed the visual bug in the XML file, and sent the fix to you in an email.
geposted Wed 30 Nov 05 @ 12:38 am
If anyone has the advanced default skin plz email it to the address in my blog. Its gone from the downloads... was there a problem with it maybe? Thanks.
geposted Tue 10 Jan 06 @ 7:02 am
geposted Tue 10 Jan 06 @ 7:15 am
