Hi,
The jogwheels on the Hercules console are quite sensitive.
I'd only like to use them to position a song (and disable them while the deck is playing on the amplifier)
Problem now is when you're not very careful you end up scratching when you just want to use the stick or push some buttons....
Any ideas guys ?
thanks
Any ideas guys ?
thanks
geposted Wed 05 Oct 05 @ 12:52 pm
Open VDJ choose SET (Config)->Remote Control.
Uncheck USE JOGS TO SCRATCH.
Additionaly you can choose a skin with the Nudge or Sractch button on the decks, e.g.
Pioneer CDJ 700S
Remiskin
DJ Console
-then you can switch to N or S at will.
Pioneer CDJ 700S
Remiskin
DJ Console
geposted Wed 05 Oct 05 @ 2:08 pm
I already unchecked the "jogs to scratch" option.
This reduces the problem but not completely as you can still accidentally turn the jogs....
(no scratching but "repositioning"..)
Can you completely disable a jog with those skins ?
thanks
thanks
geposted Wed 05 Oct 05 @ 2:33 pm
I don't think that's possible, you can only have the console ON or OFF, and then you have the option to map/re-map functions, In this case you may be able to turn them completely off or not.
Your observation is quite right though, It's the way they work with the software, too sensitive, I've requested a user controlled bar in the settings menu, that allows you to choose your prefferd sensitivity level, but It hasn't been implemented, I'm hopeing with the new console they'll do that or at least make them less sensitive..
geposted Wed 05 Oct 05 @ 3:51 pm
Maybe a good suggestion for the next version of Virtual DJ....
(to have a keyboard shortcut to enable/disable the jogwheel)
Everybody in favor say aaaaay :)
geposted Thu 06 Oct 05 @ 8:49 am
I've heard of too-much-sensitive (well... self-moving i may say..) jog wheels only about old versions of the DJ Console (bulk 1, 2) not with bulk 3. Check your version.
Ciao!! :)
Ciao!! :)
geposted Thu 06 Oct 05 @ 10:50 am
Check my version...
And...
Buy a new one ?
No thanks :)
And...
Buy a new one ?
No thanks :)
geposted Thu 06 Oct 05 @ 11:27 am
check your version...
And... if it's bulk 1 or 2 and you're pretty sure they're faulty, contact the Guillemot/Hercules support.
they've been very good at fixing faulty units (or exchanging for new ones)
good luck.
good luck.
geposted Thu 06 Oct 05 @ 2:50 pm
I see.
I'll check it.
thanks
I'll check it.
thanks
geposted Thu 06 Oct 05 @ 3:21 pm
Euh, how do I now which version it is ?
Another thing, I installed latest hercules driver and mapper is gone ???
geposted Thu 06 Oct 05 @ 6:45 pm
Speary,
I returned mine a year after I got it. Check the version. If it is the old versin hercules will send you a new one free. Go to their web site and create a ticket. They will send you back to the place you purchased it from. You will probably need your receipt. Send it back to them and they will send you a new one.
geposted Thu 06 Oct 05 @ 7:18 pm
I know.
But how do I check the version ??
geposted Fri 07 Oct 05 @ 4:48 am
