I'm looking for an external mixer, I've heard of the dm950usb, but I was wondering what other mixers would work with VDJ?
geposted Wed 05 Oct 05 @ 7:02 pm
Any Mixer could work with VDJ. But you need a 5.1 soundcard minimum. Vestax , Behringer or Pionner are good ones.
If you don't have a sound card then try Numark DM950USB or CM200USB. Even if you already have a sound card, you could use USB Mixers.
Good Luck!
Good Luck!
geposted Wed 05 Oct 05 @ 10:37 pm
i think it's better u buy an economic behringer mixer. Latency is better than every usb mixers. Buy another sound card too
geposted Wed 05 Oct 05 @ 10:58 pm
Thanks for the help guys!
geposted Thu 06 Oct 05 @ 3:31 pm
Budget: Numark
Mid-Range: Vestax
Top Range: Allen and Heath, Pioneer
Mid-Range: Vestax
geposted Thu 06 Oct 05 @ 4:25 pm
