Topic: Aquamark CRASHES - Can any one help please.
I have just bought a new system solely for VDJ. After reading some posts I thought i'd download aquamark and see how it compares. The problem is that after all the tests the screen goes black and then if you move the mouse the program exits and an error box appears.
The message says that it does not have sufficient permission and access to virtual memory, or something like that. (i'm at work right now so I can't run it again and post the message as it appears)
The system is a Pentium 3.4, 2gig ddr2, intel 925excv2 motherboard, radeon x800 256ddr graphic card, with 3 SATA hard drives and running XP pro with service pack one.
Aqua mark runs ok on my laptop, with the exeption that I can go and make dinner, eat it and have a cup of tea before it done!!!!
Please help.
geposted Mon 17 Oct 05 @ 11:03 am
Dj XeoPRO InfinityMember since 2005
are you running the test from an administrator account? you will need to use a user with full system access to run the test.
geposted Tue 18 Oct 05 @ 1:50 am
