Topic: Missing remote control 2 tab??
Hi!
I'm trying to set up time encoded vinyl/turn tables/Virtual DJ with no success. The http://www.virtualdj.com/products/timecode/ tutorial describes a "Remote Control 2"-tab that I don't have in my version?? I only have "Remote Control"-tab, without the 2...
Further more, I've connected everything else.. The turntable to an aux-in rca port and the ground to the pc's frame.
Is there another version I should have?
Please Help!!!
/J
geposted Sat 19 Nov 05 @ 5:47 pm
bogartPRO InfinityMember since 2004
Not sure, but you may need the full version for this featrure
geposted Sat 19 Nov 05 @ 6:13 pm
Arn't sure.. Read some where that in trial version one turntable is allowed...?
geposted Sat 19 Nov 05 @ 8:17 pm
acw_djPRO InfinitySenior staffMember since 2005
ASDFdddd,
Remote Control2 isn't available anymore. The actual version of VDJ works only with ASIO Drivers. If you are going to try TCVs the best is use ASIO
drivers with and ASIO compatible card. If you don't have it, you could use ASIO4ALL with your current soundcard (but you have to be aware you may have latency issues).
geposted Sun 20 Nov 05 @ 8:35 pm
