Because the dev staff seems to read this thread, i would like to point you to the following thread:
http://www.virtualdj.com/forums/8705/Bugs_report/DMC-1___DAC-2_Mapping.html
I haven't got an answer why this hasn't been corrected yet.
geposted Tue 22 Nov 05 @ 7:12 pm
@dev staff:
Thanks for having a quick look - I've looked into Dev C++ in a bit more detail and it looks like it (MinGW GCC is used as the compiler) doesn't implement thiscall in the same way as Mircosoft compilers do, which is probably why it causes VDJ to crash.
I've downloaded and installed Microsoft Visual Studio C++ 2005 Express Edition instead and am trying to compile using this, but I'm not having much luck. I get the following error when compiling:
1>c:\\documents and settings\\jpb\\my documents\\code\\vdj\\DAC3Mapper.h(120) : error C2375: 'DllGetClassObject' : redefinition; different linkage
1> C:\\Program Files\\Microsoft Platform SDK\\Include\\objbase.h(833) : see declaration of 'DllGetClassObject'
#include was required in Dev C++ to get it to compile (Otherwise I get lots of errors), and is also needed in MS Visual Studio C++ for the same reason.
I can't find any way around this problem so far - If I correct DllGetClassObject to the definition as it is in objbase.h, the DLL compiles successfully and VDJ will load with it present, but continues to use the internal built-in mappings.
How can I get around the above problem?
geposted Wed 23 Nov 05 @ 1:31 am
WHAT ABOUT SOUND IMPROVMENT ? STILL NOTHING I DON'T GET! THAT'S ALL I WANT FOR XMAS A BATTER SOUNDING VDJ.THANK YOU
geposted Wed 23 Nov 05 @ 2:42 am
it IS a better sounding VDJ ;) dl and try
geposted Wed 23 Nov 05 @ 12:16 pm
