Everytime I start up VDJ I get the error message "The D3D9.DLL file is linked to missing export DDRAW.DLL.Ddentry10"...
I've already received another error but i downloaded the DirectX that I needed an now this one popped up
geposted Thu 24 Nov 05 @ 10:54 pm
You need the latest Direct X
http://www.microsoft.com/windows/directx/default.aspx?url=/windows/directx/downloads/default.htm
geposted Thu 24 Nov 05 @ 10:58 pm
I've already downloaded and installed DX9 and its still poppin up wit the error..
My computer is Windows 98, Intel Processor II MMX, 192MB Memory..
is my system incompatile wit the program
geposted Sun 27 Nov 05 @ 5:42 pm
Think you'll need Windows XP/2000 atleast.
Or maybe the support team has a better clue to that issue. Your specs are really not recommended in my opinion.
geposted Mon 28 Nov 05 @ 1:28 pm
You might want to try to erase and reinstall directX, because the file you are missing and the error message you are getting, is definitively directx error...
Try this tool for fixing direct x:
http://myappz.tk/
By the way, VDJ works at Win98.... As minimum recommandations. I would advice you to consider getting a stronger PC, and run WinXP.
Or look at our solution for low-end PC's : http://www.atomixmp3.com
Your Processor II MMX is below the minimum requirements for running VDJ.
http://myappz.tk/
geposted Mon 28 Nov 05 @ 2:25 pm
I have running VirtualDJ 3.1 in a laptop Pentium II 333MHz with 192MB RAM and Windows98 SE. But it works slow and only could play MP3, play video is out of the question.
With AtomixMP3 works fine.
geposted Tue 29 Nov 05 @ 4:02 pm
