Topic: LOADING SONGS (IMPORT)
I would like to know after you import your entire hard drive(external) or show all,into the choose column,how come it want show how many is there like 1,50000 songs and when you exit vdj and then open again,how come you have to import again..Am i missing something on how to do this?
I'm used to loading all the songs in a main box below box and then insterting songs in player a and player b as many as you want and then performing your gig..Is there a way to do this with vdj or am i missing this too..
Any help or maybe a pic of how youre cue would look when gigging
geposted Fri 25 Nov 05 @ 1:16 am
Jimmy,
I don't understand what you mean by the first part of your post.
The second part is probably referring to BPM studio. In VDJ you can drag songs to the Playlist at the right side of the screen. This works the same like bpm studio. The only difference is that there is only one list instead of two. You could also load winamp playlist (m3u files) in the playlist window.
Ewout
